6x6 tractor revisited
Discussion in 'The Lounge' started by ryan22re, Aug 26, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    here is a pic of the progress my co-worker is making on his 6x6
    ryan
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Nice! :D
    Will that be a driven axle or just a tag?
  3. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    no, its driven. he mounted a pulley to the top of the first trans, and ran a belt between the two tranny's. it seems to work ok, but has fuel/carb issues right now, which keeps it from running too terribly long. did use it to pull a couple of cars in the shop though.
    ryan
  4. senatorwoodhouse
    senatorwoodhouse 1/2 ton status
    Jan 22, 2005
    108
    des moines, IA 50311
    That is sweet!!!!!!!!!
    Do you have any pics of the buildup?
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    cant wait to see it finished.
    but is it actualy a 6x6? i would think the fronts just steer, a reall 6x6 would be cool, i have a drivers drop 241 he couls put in:wink1:
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    no its not 6x6 but thats what we call it.
    were thinking of ideas on how to drive a front end this morning.
    but seems too much $. only real money in it now is tires. and a belt.
    ryan
  7. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    few pto u joints and some imajintation, and some fab work could be done
  8. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    That's cooler than an iceburg!
    I like it! :laugh: :waytogo: :waytogo: :saweet: :bow: ..makes me wish I hadn't scrapped a lot of the transaxles and junk I had from riding mowers!--
    I've made a few "Homebuilts" myself,but none that good looking--I have one with a differential from a Harley golf cart with a pinion mounted disc brake,with space saver spares on all 4's,a pinto 4 speed tranny,and an 8 hp Tecumseh horizontal shaft motor on it!..it also has a cast iron "beam" front axle off an old Pennsylvania tractor,with corvair wheel hubs adapted to it so chevy 5 lug space saver spares fit the front,and a dodge step van steering box!..I had to cut the centers out of the rear rims,and install centers from airens snowblower rims,that matched the weird 3 lug pattern on the rear end..
    My dilema with it is one "V" belt is insufficient to transmit enough tourqe to the tranny without slipping in the higher gears..I used a 10" pulley on the tranny input shaft,and a 2-1/2" on the motor,and its still a bit high geared in the higher ranges of the tranny.--it also has limited steering,and its way too slow ,too many turns of the wheels to steer it--more engineering required there!--.I pushed it out in the shed/greenhouse about 2 years ago,and there it sits!..awaiting destruction or resurection! :rolleyes:
    Did he use hydrostatic transaxles,or regular "manual" transaxles???...I hope both have the same gearing!...I doubt if you'll notice the front wheels not being "driven"--that thing will likely crawl over pretty much anything in its path with just the 4 rear tires driving!--the one that my friend built similar to yours with another set of wheels ABOVE the tandem axles driving the others thru friction really impressed me with its off road capabilities!--and I thought it would never work! :blush: :doah: :tongue1:
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Did Daniel @ USA 6X6 build that for you? :doah: :blush: :whistle: :rotfl: :haha:
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The welds on the fenders look to clean to be Daniels and also they have only been working on this for 6 months or so I believe that is "ludacris speed" compared to Daniel. :haha:
  11. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    they are "manual" transaxles. the front is a 6 speed and the rear is a 5 speed. he was going to swap in a 6 speed in the rear, but the 5 speed and 6 speeds have the same ratios (just one extra gear). shifting of the second trans is just like shifting the front. behind the front seat is another shift plate just like the one for the front. he can drive either set of rear wheels independently or both at same time.
    ryan
  12. sandawgk5
    Oct 28, 2003
    6,881
    That thing is def PIMP. Maybe should fab some mini beadlocks.
    Ira
  13. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    with that tranny setup would it be possible to put either axle in different gears then????
  14. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    you got it. put the front in 1st and back in reverse if you wanted to.
    ryan
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Too good of work for USA 6X6 too have been involved, LOL. If USA 6X6 built it, the wheels wouldn't be strait or able too hold air.
