7/16 wheel studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by agrezy1, Dec 17, 2002.
  1. agrezy1
    agrezy1 Registered Member
    Dec 14, 2002
    49
    yucca valley,ca
    /forums/images/graemlins/burb.gifAre the stock 7/16 wheel studs good enough for alum.wheels with 35 inch tires? or does anybody know of any aftermarket studs that might be better?
  2. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    That's what I'm running but I don't get too rough on it.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I've seen lots of snapped ones - especially from running big tires and aluminum wheels.
    I don't see why you couldn't upgrade to 1/2" studs from a late 70's F150. Might need to drill the hubs/rotors, but I can't see it being a big deal.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I had 1/2 studs on my front D44 and I was wondering if that ever came as an option or the PO drilled them out and put in 1/2 studds.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    was probably ford axle or hubs at least
  6. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    The 2wd 1/2 ton Chev. use 1/2 wheel studs. Just ask for '73-'79 2wd Chev. wheel studs.
    The knurl on the studs are bigger.
    I think I used a 41/64 drill for the holes in the axle flange after that press them in.
    Also your drum holes need to be enlarge to 33/64.
    ( THIS IS FOR THE REAR ONLY) LATERS /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
