7.17 gears in dana 60 and 14bff
Discussion in 'The Garage' started by 53chevy, Jul 8, 2005.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    I never knew they make that low of gears for 1 ton axles. Anyone know of any info on that low of gears.Is 7.17 going to be strong enough in our "small axles". Post your ideas , just trying to see what u guys think.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They dont make them for a 14b :rolleyes:
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    What 85mudblazin said... The lowest available gears at the moment for 14FF's is 5.13's. 5.38's are supposed to be out soon and there are rumors out that there may be one more lower alternative. But nothing close to 7.17's unless you go with a Dana 70.
  4. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    I saw them on ebay about 3 years ago and trying to find them again, could they even be made to go that low.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As already stated by 2 other people, there has never been anything lower than 5.13 available for the 14-bolt.
    From my understanding there are clearance issues when trying to go to anything lower than 5.13, with speculation as to whether any clearaning inside the housing will be necessary for 5.38s.
  6. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yep, if you want anything lower than 5.13s... get a D70. D80s might go that low too, not sure. Of course, there are always rockers at 6.72... or mogs at 7+:1...
    j
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I hate to rain on your parade but like the others have said 7.17's for a 14FF just ain't so - not ever ! If someone posted such a thing on e-bay they were in-correct or just plain talking trash.
    Tom
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    IIRC when I read a post on Pirate it said that mods to the housing are neccessary to run 5.38's. If you want gears lower than that, run a dana piece.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    there was a 6.17 for the eaton H110 axles(11,000lb axle), was an optional and low numbers available axle for the 72 older c-30's(over the standard and common H072 axles)
    and is probably in a ton of the old c50 and/or c-60's
    maybe the 7.17 is actually the 6.17
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    About the only thing that I have ever heard of that used 7.17's was in an airplane tug.
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    The axle in question is a 14 FF not a H110 or H072. :confused:
    From what I have learned the H110 offered a 6.17 and U2SLOW found some literature that supports the H072 coming with a 5.83 gear instead of the previously believed 5.14 max gear.
    But , for this topic we are all talking about the 1973 on up 14FF and such high numerical gear ratio's just don't exist .
    Tom
