7/8 Ton Conversion a Success!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Sep 19, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Well, I finished the D44 install on Thursday around 3:30pm, and left for the beach around 5pm. The truck ran flawless all the way down and back [​IMG]
    I've now got a 14B FF with 1 ton brakes and a 3/4 ton D44 front, hence my 7/8 ton truck [​IMG]
    4-wheel worked great! I had no problems and was very impressed with how the 4.10 gears did in the sand. The truck just crawled over everything I aimed it at [​IMG]
    Thanks to everyone who made this possible - Boss, Rocko, Kyle89K5, Lake Tex, and all the others who have offered invaluable advice! I cannot express my appreciation enough.......
    WooHoo ..... I have 4-wheel drive again [​IMG][​IMG][​IMG]
    Thomas.
    -- '84 K5 Blazer --
    <a target="_blank" href=http://stoopalini.off-road.ws/blazer>My Blazer Site</a>
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Good News Man!!!!! [​IMG][​IMG][​IMG]
    Glad you got it running!
    Kyle
    89K5
  3. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Excellent...
    Gotta get mine done now.. then we'll plan a trip to the Slab again for next month.
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Haven't seen you in a while. Now I know what you've been up to. And that's what I'm talkin' about!! [​IMG] Glad to hear you got everything together and running excellent. Take care.
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Thanks guys, I am very pleased with it [​IMG]
    Rocko, the slab sounds like a plan! How about Saturday, the 29th? Lemme know and we can start arranging a trip.
    What do you have left to do to yours? Just the brakes, right?
    Yea Boss, I've been working my arse off getting this done. Man, 8 lugs all the way around looks so cool! [​IMG]
    Did you know that the 14B FF you sold me had 1-ton brakes on it? While searching for another drum to fix the axle seal leak, I went through 2 before I figured this out. The drums were from a 3/4 ton 14B FF and they were too small [​IMG] Luckily, the hubs are interchangable. I was able to seal the leak with one of the hubs and the ole' speedi-sleeve trick.
    Thomas
    -- '84 K5 Blazer --
  6. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Brakes and Front end alignment..
    Then she's ready to rock.
  7. Boss
    2,550
    Maryland
    Yeah, I thought I told you that. 3/4 ton 14bolt with 13" drums (1 ton drums). Remeber I had to get the drums seperate for you? 13" drums works a lot better and cooler (like temperature cooler), than 11" 3/4 ton drums.
    Anyhow, i'm glad it's working :) Take care and wheel the sucker hard!!
    Boss
  8. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Slab? Are y'all referring to "The Slab" near Marble Falls Texas? That is my old stompin' grounds!
    '85 K5 : Run it til it breaks, then fix it and go again!
  9. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    That would be the Slab... Great place for off-roading..
    Thomas.. won't be able to make it to the Slab the 29th..
    My unit is getting activated til the end of the month and possibly longer.. No free weekend's for me for awhile..
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Actually, just because the drums are 13" does not mean its a 1 ton size drum.
    13" drums come in two sizes. 2.5" wide shoes are on the 3/4 tons, and 3.5" wide shoes are on the 1 tons.
    11" drums are on the older 3/4 tons, and they use 2.75" wide shoes.
    Just because someone says there is 13" drums on the rear, does not automatically make it a 1 ton. The width of the drum needs to be known and measured before confirming a 3/4 or 1 ton.
    Just wanted to let everyone know the 3 differences between the 14FF brake drums. [​IMG]
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  11. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    The 3/4 ton drum I tried to install fit on the axle circumference wise, it just left a huge gap between the back of the drum and the backing plate because It wasn't deep enough.
    Is this what you mean?
    If you put a 13" 3/4 ton drum and a 1 ton drum on the floor with the hubs facing upward, the 1 ton would be taller, right?
    -- '84 K5 Blazer --
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    EXACTLY!!! [​IMG]
    If you took a 3/4 and 1 ton drum without the bearing hubs, the 1 ton drum would sit taller than the 3/4 ton.
    There is no mistaking the 1 ton drum for a 3/4 ton. Its just HUGE!!! The 3/4 ton drum just seems "narrow" than what those "other, bigger" ones are!!! [​IMG]
  13. Boss
    2,550
    Maryland
    I hear yah K30. But the ones I sent Stoop was definately 1 ton drums. They are just plain huge is the best way to describe em [​IMG].
    Boss
  14. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    ahhhhh, cool; So my earlier diagnosis that I have 1 ton gear on my 14 bolt is correct! [​IMG]......... LOL
    Thanks man, you can see how I was confused when I tried to install the drum, and it was too short! I guess if I had listened to Boss when he told me they were 1 ton brakes, I could have saved myself a lot of thought process; and we all know how much thinking can hurt .... [​IMG]
    Boss has it right on, these things are freakin' huge! I pressed new seals in them more times then I can count. I had to pick them up and put them onto my press. not really a big deal, until my back tells me so ......... LOL ....... they are h..e..a..v..y!
    Thomas.
    -- '84 K5 Blazer --
