7.8L D-max diesel, cool!
Discussion in '1982-Present GM Diesel' started by steelsoldiers, Feb 28, 2003.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I just found some specs on the GMC medium duty truck site. I had no idea that they even made a 7.8L Dmax /forums/images/graemlins/eek.gif. I guess I am out of the loop! /forums/images/graemlins/rotfl.gif Here's the specs:
    275 hp (205 kw) @ 2200 rpm and 860 lb-ft torque (1,161 N-m) @ 1,450 rpm. Engine Speed Limited to: 2,400 rpm.
    I wish you could get that in a 3500 4x4 /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif. Maybe they'll make a crate motor /forums/images/graemlins/thumb.gif. I'm sure it a helluva lot heavier than the 6.6L, which is a monster in itself.
    Chris /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. steelsoldiers
    Oct 17, 2002
    365
    Here's some more specs: Turns out it's a inline 6-cyl.
    Duramax 7800 275 Horsepower
    Displacement: 7.8 Liters / 475.9 Cubic Inches
    # of Cylinders: 6 In Line
    Bore: 4.53 Inches
    Stroke: 4.92 Inches
    Compression Ratio: 16.0 : 1
    Dry Weight: 1180 pounds
    Fuel Grade: # 2 Diesel
    Engine Power: 275 HP @ 2200 RPM
    Torque: 860 pound Feet @ 1450 RPM
    Governed full load setting: 2400 RPM
    No Load Governing speed: 2550 RPM
    Low-Idle, Curb Idle: 600 RPM
    Oh yeah!! /forums/images/graemlins/grin.gif
  3. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    that engine has actually been out for a while. Its just an Isuzu engine that now carries the Dmax name.
    Did you check out the new 4500/5500s? I believe the 4x4 CrewCab versions are coming out as 2004 models /forums/images/graemlins/thumb.gif those have the 6.6 Dmax or 8.1... no 7.8 Dmax or 7.2 Cat /forums/images/graemlins/frown.gif
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I talked to the Duramax techs at the plant in Moraine, Ohio a year and a half ago when I toured the place. As was mentioned, the 7.8L was existing technology when GM and Isuzu joined forces. I asked why they weren't pushing the 7.8L, and they said it was because it really wasn't a new design like the 6.6L. It was just simply wearing the Duramax name plate.
    When you consider that the 6.6L makes 300 hp and 520 ft. lbs of torque, and can easily be modified to produce much more, the 7.8L really doesn't have much of an advantage over it for the pickup truck market.
    Casey
