70 dana 44 ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JIMs70K25, Jan 30, 2003.
  1. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    1970 dana 44-8F front axle: 30 splines or 19 splines on inner axle? Or do all GM 44s have 30 splines and other manufactures used 19 spline inners?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    99% sure all GM D44 fronts are 30spline /forums/images/graemlins/thumb.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Jim,
    This may or may not help you, but my 1971 Dana 44 is 30 spline. /forums/images/graemlins/burb.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I do know that all the disc brake D44's had 30 spl. However the 1st gens got small D30 sized u-joints...the 73- shafts will swap in to cure this.
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    not to try and steal your post,but how do youy know if the 73 and later axleshaft have been swapped already?im not sure on mine and i would not want to break one on the trail if this would be a good swap for strength.
  6. Burt4x4
    6,854
    The 73 and up shafts have the bigger Ujoint in them. Spicer # 5-297. If you were to goto a parts store near you and get a 297 from the counter(or any brand's ujoint that replaces a 297) and tell the parts man you just want to compare the cap size to the one on your rig. most likly he will let you walk out with it to compare it to what you have in you rig. Turn your axel so you can view the cap and you will know right away if yours is smaller than the 297 cap.
    Good luck
  7. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i'll try it and see thanx man.
  8. Burt4x4
    6,854
    Rock On! /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    FWIW, Bill O'Grady a t Vintage Chevy told me that some '72s had the 297 U-joints in them stock. The parts books at some auto parts stores bear this out and a good parts guy will ask you to bring in the U-joints on a '72 so he can match up replacements.
