70 GMC 2WD brake conversion question.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wildcatkit52, Nov 17, 2005.
  1. wildcatkit52
    wildcatkit52 Registered Member
    Apr 12, 2005
    65
    Arkansas
    Any knowledge or sites on converting from front drum to disk? Can newer body style parts be used? I just started searching this and haven't found much of anything except for off-the-shelf conversion kits, or trying to find factory 71-72 stuff that isn't trash. I am looking for the cheapest method to get this truck stoping better!
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The guys at http://67-72chevytrucks.com/vboard/index.php deal with this a lot. I think I can remember reading that the '73 to '87 stuff will work; you just unbolt the entire front crossmember/suspension and then bolt it under your truck. Do you have a 1/2 ton or 3/4 ton?
  3. wildcatkit52
    Apr 12, 2005
    65
    Arkansas
    Thanks! Just the type place I was looking for... It is a 1/2 ton. Looking for the best/easiest/cheapest way to get disks on the front... Those dang drums are a bit past their time!
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    hey, my roommate has some stock 72 disc spindles that he needs to sell. He went to drop spindles so he doesnt need these. I dont see why you couldnt get new rotors and calipers and be done with it.
  5. wildcatkit52
    Apr 12, 2005
    65
    Arkansas
    How much for the spindles?
  6. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    how I did mine, was ordering some 2.5" drop spindles for 269.00 from ECC, then you use 73 and up calipers and pads.
    dont forget to swap to a disk mc and porportioning valve.
  7. wildcatkit52
    Apr 12, 2005
    65
    Arkansas
    That would work but I don't want to drop it. I am also looking for a good way to swap to 5 lug on the 12 bolt rear. I am looking into swapping axle shafts as the rear is a posi and I don't want to stick any old rear in to replace it...
  8. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    ECC ALSO SELLS STOCK SPINDLES, I have also seen a few sets of spindles on ebay.
  9. wildcatkit52
    Apr 12, 2005
    65
    Arkansas
    Yeah. I will more than likely do the crossmember/suspension swap from a '73 to '87 body truck as they are plentiful around here and everything I would need would be there. I talked to Currie Enterprises and they said the easiest way to change the rear to 5 lug would be have the current axles redrilled for that pattern. I wonder what 6 lug hubs and discs would fit on the later hubs? So many questions, not enough experts... :doah:
  10. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i bought 6 lug disc brake rotors that replace the 5 lug rotors from one of the classic parts catalogs, chevy duty maybe. personally if you own a 1970 truck, i believe it should have six lugs. avoids confusion at the swap meet. when you upgrade your spindles from a different year range, make sure your ball joints match your new spindles. I think there are differences in diameter and length of the ball joints between years and weight ranges.:k5:
  11. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    the ball joint differece is between the 3/4 ton and 1/2 ton
    my truck use to be a 3/4 ton 8 lug,
    when I ordered the spindles I got to keep the 3/4 ton stuff but convert to 5 lug with a disk and 2.5 inch drop.
    kind of confusing :D
