70 gmc jimmy front differential?
Discussion in 'The Garage' started by needed help, Dec 23, 2004.
  1. needed help
    needed help Newbie
    Dec 23, 2004
    missouri
    Could someone please help me I have purchased a 70 gmc jimmy 4x4 for my son. I need to replace the rear end "someone has put a 5 hole rear end on it". Since I need to do this, I thought I would swap out the front so I could put a later model with disk brakes. Could you tell me what years would be a direct bolt on.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Anything up till '91.
    Harley
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    All GM fronts are a direct swap as far as spring perch width. Brake lines may vary between a 10 bolt and a Dana 44 (what it has now). The rear was originally a 12 bolt, but a 10 12 or 14 bolt will all fit with adjustment of the spring perches. I believe 69-72 perches are narrower by a couple inches. Hope this helps.
  4. needed help
    needed help Newbie
    Dec 23, 2004
    missouri
    Thank you....!
  5. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Just swap the axle shafts??
    If the rear end is the correct ratio to match the front,and the only problem is you have a 5 lug rear,and a 6 lug front,you can swap 6 lug axles into a 5 lug 2wd axle ,they interchange,just find some 6 lug axle shafts at the junkyard....:crazy:
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    unless you are doing a total 100% resto, ditch the front axle. '70 was the only year GM used open knuckled front d44's with drum brakes, and the drums are specific to this year, and are hard to find. it would be less of a headache to just convert to discs, but that is my opinion.
