70 K5 gas tank
Discussion in 'The Garage' started by big red convert, Dec 15, 2005.
  1. big red convert
    big red convert Registered Member
    Nov 19, 2003
    6
    Little Chute Wisconsin
    Hi my gas tank is leaking like a sieve, and was wondering if anyone was getting rid of a polly gas tank, or know ware I should go through to get one?
    Thanks,
    Adam
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Browns of Two Rivers has Poly Tanks... they list an all Steel one, but when I called they said they couldn't get it anymore. I have the very same problem when my tank is over half full. I'm about to break down and buy the poly tank, even though it will ruin the originallity even more...
    By the way... Search them on Google... they'll come up from across the country I think. They are based in Two Rivers Wisconsin
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Check out Gas tank Renu. They take your tank, weld up any huge holes, dunk in in expoxy. They are good for life. Never rust, still steel. And usally only around $100.
  4. big red convert
    Nov 19, 2003
    6
    thanks for the advice, I will look into it because I cant stand gasing up a little each day.
    Thanks,
    Adam
  5. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    alternative..??
    I had a 72 K5 with a leaky gas tank too...I lucked out and found one in another mint truck just like mine a guy had ,he got drunk on easter sunday and T-boned a fire hydrant,and totalled the truck..I bought the gas tank,complete 4 spd setup to replace my TH350 setup,brake booster,etc..guy had just replaced the tank about a year earlier,with a genuine GM one he searched dealerships for across the country..one in Kansas had one!..
    But while I was searching for a tank (and this was in 1984 or so!)--they were not readily available even then!--GM stopped making them after 10 years,and for some reason aftermarket companies focused only on 73-87 K5 tanks..J.C Whitney had both steel and poly ones listed in their catalog at the time..IF you had 300-400 bucks to buy one.(It might be they still list them maybe???).---so I started looking in boneyards for a stock one,or anything close that might fit..
    I found chevy "G" series Vans had a very similar tank,in dimentions, and the gas filler came out in the same area..and Dodge Vans,and Ramchargers in the late 80's had poly tanks,and the Ramcharger one looked like it would fit in with modifications...but the sender unit from a Dodge won't jive with a Chevy gauge..(I had a Dodge poly 40 gallon tank in my 74 GMC--it made my gas read read backwards !--empty when full,and full when empty!--but it was accurate!:eek1: )...so maybe if you cant find or afford the bolt in tank,one of those might get you by...:crazy:
  6. big red convert
    Nov 19, 2003
    6
    good advice, I never thought of looking on other make vehicles before, thanks.
