700 acting up !!!UPDATE!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonny-K5, Mar 14, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    just came back from the local mud pit and i get on the freeway, no overdrive. shifted fine beforehand. so i drive 20 miles in drive til i hit traffic and in stop and go driving the truck didnt want to shift. it would hold 1st too long then slam into 2nd.
    ive been planning on getting a bowtie overdrive tranny, just wondering if there is something small i can replace in this tranny to keep it going a little longer. its got over 140k so im pretty sure its toast and in need of a rebuild, but you never know.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 700 acting up
    Maybe the TV cable came out of adjustment or maybe you stripped the governor gear... /forums/images/graemlins/dunno.gif
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    Re: 700 acting up
    im willing to bet its something internal like the governor gear. if the TV cable came out of adjustment, would that keep it from shifting into OD? if i switch from D to OD it loses engine braking as well, which also makes me think its something internal.
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Re: 700 acting up
    My 700 did the exact same thing a few weeks ago. First, it lost od. Then it would hold first wayyyy too long. Then it just wouldnt shift out of first period. It is the shift governor. Pop the cover for the governor off (its on the drivers side top of the transmission) with a screwdriver, and pull out the governor. I bet it is either stripped or the plastic gear on the end is broken off. Find a local transmission shop, and you can get it done cheap. Dont let them try to sell you a whole new governor. Just take them the governor, and they can just pop the plastic gear on the end off (which is what messes up), and put another one on for like $5. Im 99.9% sure that is your problem.
    -Harrison
  5. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    Re: 700 acting up
    87BrnRsd,your a lifesaver! i'll check out that governer gear tomorrow. /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    Re: 700 acting up
    i just pulled the cover off the shift governer, looks perfectly fine.... what else could it be? no OD and occasionally lagging shift.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 700 acting up
    If you lose third too, it's done.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: 700 acting up
    i say that its done already, most of the time OD goes first. once in a while reverse goes first
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Re: 700 acting up
    yup... chuck it, its done.
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 700 acting up
    [/ QUOTE ] Then 3rd, 2nd, and 1st.
  11. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    Re: 700 acting up
    well, i blew the valve out with compressed air and it fixed the problem. thanks for the help guys.
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    489
    Grand Rapids area
    Re: 700 acting up
    The governor valve?
