700 problems.
Discussion in 'The Garage' started by darkshadow, Dec 7, 2006.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    I have been driving this 89 suburban (350/700) for a few weeks now just bought it from ebay.
    when driving it home 700 or so miles, it drove fine but seemed a little sluggish to drop into passing gear, but did 65/70 the whole way home.
    Now the downshift is horable highway or street, is i press the gas hard,, it seams like the cluches are slipping as the moter revs with the down shipt but I dont get any power, on the highwya i will slow down a bit, so hard acceleration is out as it does the same.
    To night on my way home it started to delay shifting, and wil rev hugh befor it shifts Hard.
    from a stop it wont shift untill 30 mph.
    the fluid is dark, but does not sell burnt, any ideas, how much of a rebuild i will need?
    was going to change the fluid myself this weekend, or would taking it in to do a flush be better?
    dave
  2. Ryaner9
    Ryaner9 Newbie
    Feb 25, 2006
    ill
    flush it. run some fluid threw it to clean it out good and the buy some trans x and run it like that. It saved my trans.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Checked the TV cable adjustment?
  4. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    no.
    like i said just got it and need to put it on the road right away, hell it the first 700 i have had in years, 400 in the old burb.
    where do i adjust the cable from?
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    The throttle body. Pretty sure there is a link posted in most of the 700 threads that has the info on how to adjust it.
  6. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    cool thanks brother
    guess ill see up at 5, guess ill see how it drives in the morning, the do some work this weekend :dunno:
  7. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    OD is for pansies, replace it with a 400
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if it seems like its getting worse almost daily, its gonna need to be rebuilt completely.
    but first, check the TV cable. push the button in and grab the cable and move it away from the TBI/carb, release the button. then cycle the throttle all the way, it will click out. try it there, if its two soft, push the button and move it away 1 click at a time. if its way too hard move it closer 1 click at a time. you want more hard than soft.
    if that doesn't help any pull the governor out (stamped steel cover on the driver side at the rear of the case) make sure the gear is good and the valve is not sticking, broken springs or anything else that doesn't look right.
    if you can't figure it out, give me a call after 4pm(still got my numbers? try my home first)ill try to work it out over the phone.
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If the fluid is dark it is burnt. Does not matter what it smells like.
    If the fluid is burnt in a 700 your tranny is prolly burnt too.
  10. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    First off, DO NOT FLUSH IT, putting new fluid in WILL (and i repeat WILL) make this thing neutralize, ive seen this happen way tooo many times to tell whats going on here, plan on a complete rebuilt but until then check and make sure of max Tv pressure and limp it around, BTW, with me working at a trans shop and being a part time builder on the side, go to a good known trans shop and ask them how much they want to do a bench overhaul, 6-700 bones(on average for a stock overhaul) and you can remove and install it yourself and save a couple hundred... Nate
  11. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    really?
    i sould not flush it at all???
  12. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    well adjusting it is the least of my worrys.
    I drove it to work yesterday dident drive half bad, but after a stop on the way home really started to slip, and locked up on me!
    never had that happen befor, back tires locked up and i screached to a halt, so i towed it to a gerage, I am jeadding there now to see what they say.
    The worst thing is is that i really want to complane about it but can't becuase i only paid 615 bucks for it so it hard to bitch when i got such a deal :dunno:
  13. nocoasthardcore
    nocoasthardcore Registered Member Premium Member
    Nov 22, 2004
    45
    15
    Colorado
    The 700 in my 89K5 started acting the same way on a drive across the state, luckily on the way home.
    I changed the fluid and filter(I did not flush. Have seen to many high milage trannies die after a flush to try that. But for a new or low milage tranny I do believe in the flush service) and a can of TransX and a pint of Lucas Oil.
    It lasted just under a year normal back and forth to work driving, about twenty mile round trip.
    But it did eventually go out. And in a bad way.
    Limping through the Kansas country side at fifteen miles an hour was not how I had planned on spending my afternoon.
    See what new fluid will do and plan on a rebuild.
    I was lucky enough to have a brother working at a Chevrolet dealer ship and he got a parts and labour discount. The three year/thirty thousand mile warrenty with roadside gives nice peace of mine.
  14. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    read post above, trannys pooched, locked up on me.
