700 r-4 questions
Discussion in 'The Garage' started by Guss, Feb 10, 2006.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    90 blazer with 700 r-4 with i love but the front seal is leaking and every thing i read indicates front pump probs. or toque converter my main question is the converter the same thing as the front pump or is the front pump internal????
    some one please help this isnt one of those problems you can baby along
    and its my dd.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    its prob the front seal that is in the pump, and seals on the converter.
    or the seal from the pump to the case.
    two different things.
    both mean that your tranny has to come out.
    either one you can fix yourself. i.e. no special tools needed.
  3. Guss
    Feb 6, 2005
    78
    houston
    im confused are the pump and the converter two different items and if so is the front pump in the case
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes the converter and the pump are two different things. the pump is internal, you must pull the pan and remove a few things to remove the pump.
    if the seal is leaking, sometimes the bushing behind it is bad allowing it to leak. you need to remove the pump to replace the bushing. some tranny shops have the $$$$ tool to remove the bushing without pulling the pump, but most do not. you must remove the tranny to replace the seal. when you pull it out, look at the bushing and see if there are any scratches or if the yellowish color is gone, its bad and needs to be replaced. also look at the converter hub to see if that surface is bad. if it is, you need a new converter.
  5. Guss
    Feb 6, 2005
    78
    houston
    thanks
