700-R4 and B&M Trick Shift
Discussion in 'The Garage' started by Hardcore, May 19, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    I'm putting a deep tranny pan (+2 quarts) on my truck.
    I know when I change the fluid only 4 out of the 10 quarts come out. I'll be putting in 6 quarts of new fluid. My question is will 6 quarts of Trick shift and 6 quarts of old Dexron II mix right?
    Anybody use the trick shift? /forums/images/graemlins/ears.gif
    I did a search and found that some of you guys use a quart of Ford ATF to firm up shifts, can someone please explain?
    Thanks /forums/images/graemlins/thumb.gif
  2. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Anyone??? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I have and getting ready to go back to it. but I get crazy with it and just fill it to the rim with B&M........
  4. I've used it and if I recall correctly on the container is states that you can mix it with regular tranny fluid to help reduce foaming. When I had my 700r4 rebuilt I filled it with Trick shift, and at $7/quart I had a hard time bringing myself to change the fluid for the first time. /forums/images/graemlins/tongue.gif
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have not done it on a 700r4 but on my th350's and th400's I run Ford ATF. B&M even tells you to run ATF instead of the Dextron. I ran the trick shift fluid years ago and outside of it being blue I didn't notice much difference in the shifting between that and ATF.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    OUCH!!!!! Where ya buying at, RapeMyA** Autoparts? It's less than $5 a quart down here.
  7. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    You know Bubba, I'm still trying to figure out where "Down Here" is for you. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The Valley dude!!!!!! Hang ten!!!!!!
    Actually, I'm stuck between Bakersfield and Fresno.
