700-R4 deep pan options- (did a search need more opinions)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Jan 27, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I think my tranny pan is warped because I have changed the gasket and fluid twice and it has leaked from the back of the tranny pan ever since. I even tourqued the bolts down to proper specs. I am considering a deep pan possibly one with a drain plug. This is what I have found so far:
    B&M deep tranny pan
    Although I am not a fan of the chrome, I could deal with it for the extra capacity and drain plug. Do you guys know of any other options for a deep tranny pan? Also, which is better aluminum or steel?
    Thanks guys
    Ross /forums/images/graemlins/thumb.gif
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have one of those B&M's...its in my garage because the exhaust crossover pipe was too high, and the pan wouldn't clear the filter when putting it on, had to pry on the exhaust pipe a lot. If you have a different exhaust setup it would work fine though, i'd sell you mine if you want
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I run the TCI aluminum deep pan. I bought it used from here. The fins have been slightly ground in the front to clear the factory crossmember.
    For aluminum vs. steel, first off you couldn't grind the fins for better clearance on a steel/chrome one! Second, aluminum will cool and dissipate heat better than a steel one. The aluminum is also much thicker than the steel one. However, steel is stronger and would stand up to beign bashed on the trail more than an aluminum one. I carry my original pan as a spare off-road in case I put something through the aluminum pan.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] I hope you carry about a case of ATF too. /forums/images/graemlins/wink.gif A busted tranny pan will dump out a LOT of fluid before you get the engine shut down. /forums/images/graemlins/shocked.gif
  6. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I get it in gallons from Walmart.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That's the spirit! /forums/images/graemlins/thumb.gif
  8. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Steel is more forgiving, steel will dent..... aluminum in most cases will just crack or a chunk will pop out of it. In a 4X4 I'd stick with steel.... but then again I'm not smart enought to carry another pan and fluid to replace it if I break it.
  9. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I bought mine off ebay for like $20. steel pan with a drain plug. Its been of twice, and still no leaks. I think it was a B&amp;M pan.
  10. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Have any of you guys had clearance problems with a deep tranny pan and the stock exhaust? I know 90k5 did but I looked under my truck today and it looks like the exhaust is low enough to not interfere with a deeper tranny pan.
    Thanks for the input thus far.
    Bubba have you had any experience with those pans?
    Ross
