700-r4 lockup or non
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, Apr 26, 2002.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    Ive just finished getting my trannie rebuilt (85) 700-r4 Now just have 1 more hour of work to do.The trannie guy said he could make it non-lockup with a cheater 2 t-converter for an extra $400 he said it would iliminate a lot of heat.Should I go with this or just leave it stock lock up.Any advise would be apprisiated. Im going to the shop on monday.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Leave the lock up style TC in it.
    Non lock up might work in some applications for a light car but not for a big heavy Blazer. Running it without a locked convertor will acually generate more heat when in overdrive because of slippage . Thats not what you want.
    You will also get better gas milage with a lockup convertor
    I think the tranny guy is giving you a line of BS to sell you a $400 torque convertor
    Heres a link with a lot of info on Lock up vs. non lockup: <a target="_blank" href=http://www.700r4.com/Tech/TCC/introindex.htm>700r4.com</a>
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, so if the TC is not gonna lock up and continue to slip, how is that gonna preoduce less heat? Ask the tranny guy that!
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I think your tranny guy is a bit confused. or just b.s.ing to get mo money! the slipping of the converter is what causes the heat! no lockup in overdrive? way to much heat. will recook tranny.
