700 r4 Question
Discussion in 'The Garage' started by johnathan, Dec 11, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    The 700 r4 in my blazer has 5 gears total.It shifts through 4 gears before overdrive.All the other vehicles I've driven with 700r4s only have 4 gears total.My tranny was built right before I bought it .I know it has a trans-go shift kit.Why does mine have an extra gear??
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    you should have 4 forward gears, reverse, neutral and park
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    I can count the gears as they shift 5 forward gears.I have had other people count with me
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    That fifth gear you feel is the torque converter locking up, all its doing is stopping the slippage in the transmission. If you go down the road, at cruising speed, with your foot on the gas, tap the brake pedal and you will feel this "fifth" gear go away when you tap the pedal and comeback when you let off the pedal.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    are you smoking the reefer? jk hmm thats weird, maybe it has one of those overdrive kits on it in addition to the factory overdrive. do u get good mpg with it at least? or maybe its what ^he said
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    preeeeeeeeeeeecisely
    I have a 4l60E in my DD and a 700 in my trail truck. Both have lockup convertors that "feel" like it has another gear.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    No 5 gears in 700r4. Only 4. The last shift you are feeling in the torque convertor locking up. When it lockes up. The 200 or so RPM drop makes it feel like it shifts 5 times.
