700 r4 swap to trubo 350 in my jimmy
Discussion in 'The Garage' started by cavscout19delta, Jan 18, 2004.
  1. cavscout19delta
    cavscout19delta Registered Member
    Jan 18, 2004
    26
    Fort Knox , K.Y
    I blew my 700r4 up along with my motor (stock 350).
    i just did a master kit on a th 350 trans and did my motor 60 over with a new cam and crank. what problems can i expect? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i think this is direct swap, they are 27 splines, both but the 700r4 mount is about an inch more behind or forward than th350 and thm200c i know, but that doesnt matter on 4x4
    good luck
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Leave it up to a scout to destroy something /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Welcome aboard and hope you stay, we need more scouts around to counteract all the Jarheads around here.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You'll need an adapter to mate the TH 350 to your transfer case.
  5. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    hooa, thanks im not relly desroying but the army wont let me take my humvee off post just to play /forums/images/graemlins/angryfire.gif
  6. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    ya i found that out after 4 hrs on the phone to every tranmission shop in town looking for a short shaft and then tearing the trans back down to put the right one in. /forums/images/graemlins/angryfire.gif
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Where are ya stationed?
  8. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    If your tcase is a 208
    find a 205 for the th350
    you will also need a crossmemeber for th350
    and drive shafts modeified,
    and if you have factor exhaust
    the y pipe might be in the way
    so look into dual exhaust.
    i did the same swap a year ago,
    Thats all i can remeber changing
    Good luck it's well worth the time and money
  9. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    right now im at fort knox ky but im going to fort hood texas in 90 days. im trying to get back home to westminster,co (fort carson)
  10. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    yes my transfer is the 208. i bought that adapter plate for the th350. will i need another one or just the cross member? /forums/images/graemlins/ears.gifi still have the stock gears (3:42) and im running 35 12:50 15. i still run the hard roads , should i change to 3:73? /forums/images/graemlins/ears.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Without OD, your 3.42s will get you around fine, just be a little sluggish.
    If you do change gears, go at least to 4.56 or don't waste your money.
  12. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    If you do much Highway driving the 4:56 isn't your best bet... I think the 4:11 is a better all around chose without having OD... My top speed on the highway is about 68mph. and I'm running T-350 and 35's.... I want to find a 241 0r 208 t-case to change and get the OD for the highway..
  13. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    thanks for all the help. i'll run these 3:42 for a while and see how i like them. I've got a set of 3:73 just collecting dust. I'll try anything for more power on and off the road. Hooa /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif also where in Ill are you i have family there
  14. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    I dont do a whole lot but i dont want to be red lined going down the road. what gears are you running? I need more than 68 mph on the highway. /forums/images/graemlins/pimp1.gif
  15. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have 4.10's, 35's, and a th700(OD). I like it a lot for freeway cruising because I can keep my RPM's around 1600 to 1800 and get decent mileage. If I could pick any ratio I would probably wan't 4.56's because it would be a little quicker off the line and probably better MPG in town but still MPG would suffer on the freeway compared to 4.10's. /forums/images/graemlins/thinking.gif With a non OD tranny I wouldn't wan't anything lower than 4.10's with 35's, just my opinion though.
  16. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    i have a 350 motor
    with a th350trans
    and what the sticker says is 3.08 gears
    and ive had it upto 78 with no problems
    thats using my gps as the speedo
    i really need to pull the cover and check the gears,
    to cold and to damn lazy /forums/images/graemlins/smile.gif
    and yes you will need a crossmember for a 350
  17. cavscout19delta
    Jan 18, 2004
    26
    Fort Knox , K.Y
    cool 78 is fast enough for 35s. well see how these salt flat gears (3:42) do but ill change them if im not getting off the line quick enough. I know i want my cake and eat it to but theres got to be a solution
  18. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Id love to have 3:42 gears
    if you upgrade i might be interisted in em
    Well let me know how it
    turns out
    also instead of regearing
    look for 3/4 ton axles with the gears you want
    cheaper than having the 1/2 tons regeared
  19. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I'm running 4:56 gears, 350, t-350, 203 t-case, & 35" tires.
  20. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    /forums/images/graemlins/rolleyes.gif But not too many...might lower the collective IQ too much /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
