700-r4 to np241
Discussion in 'The Garage' started by 87'k5boggin, Mar 4, 2007.
  1. 87'k5boggin
    87'k5boggin Registered Member
    Dec 9, 2006
    76
    pascagoula,mississippi
    i have a 87 gmc jimmy with the stock tbi 350 and 700-r4 along with the np208 t-case and 10 bolts with 4.11's and rear limited slip, i have also put on a 4'' rough country lift kit and 36'' super swamper tsl/sx's.
    I have heard of the np241 case having excellent low range and can have the slip yoke eliminated. My question is, does this t-case have any advantages over my 208?
    Thanks,
    Caleb
  2. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    It has the same low range as your 208. The advantage is that you can SYE it. IF you get one, make sure it has a mechanical speedo on it, 1989 I belive.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The 241 is a slighty better t-case as it has an oil pump in it unlike the 208, rumor has it that the 241 has a larger chain and it is 2.72:1 rather the 2.62:1 that the 208 has. Yes you can easily SYE the 241.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Actually the 241 has a slightly better lowrange (2.72 vs. 2.61) then your 208 and you can get a SYE kit for the 241. The 241 is a slightly better case then the 208 but unless you need the SYE right now or the 208 is busted then I would leave the 208 alone until you need to swap it.
    Harley
  5. 87'k5boggin
    Dec 9, 2006
    76
    would it be a worthwile swap? What kind of of drive shaft issues will there be?
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    In stock form the 241 is a direct replacement for a 208. Like Harley said, it isn't a justifiable swap unless your 208 is broke or you need the SYE.
  7. 87'k5boggin
    Dec 9, 2006
    76
    ok thanks, also is it any stronger than the 208?
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    marginally
    Harley
  9. 87'k5boggin
    Dec 9, 2006
    76
    thanks for the info everyone!
