700-r4 trans
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kustom71, Oct 18, 2003.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    I just finished my tpi swap into an 86 k5 and I went for a drive.I started out with the trans in 1st(low)just to run it through the gears and it automatically shifted into 2nd when the rpms got up to around 2000.I wasnt flooring it or racing around just wanted to get everything moving again and then this happen.Inever heard of anything like this before has anyone else?Im hoping it dosent need to be rebuilt already only about 35,000 on this rebuild.Can anyone help??????
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I have heard of that happening before, it has something to do with different valve bodies that will or will not allow that to happen.
  3. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    are you sure the linkage is et correctly? perhaps what you think is 1st is really 2nd,....just a thought.
    i have a 700r4 and have rebuilt the valve body plenty of times and never had that happen unless the linkage isn't set correctly. /forums/images/graemlins/thinking.gif
  4. kustom71
    Mar 14, 2003
    117
    NJ
    ill check the linkage but i think its good!It shifts fine in drive i just never expected that to happen???
  5. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I've heard of that too. Under certin conditions some 700's will actually shift into 2 while in manual low.
  6. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    adjust your detent cable maybe? /forums/images/graemlins/thinking.gif
  7. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    The governor may be what forced your shift to second. You had better doublecheck your TV cable is connected before you fry your tranny.
  8. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Make sure go get some info from experianced people before adjusting that cable also... Like was said, if it is disconnected, or way out of adjustment, don't drive it. You will fry your tranny! I am speaking from experiance /forums/images/graemlins/blush.gif
  9. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
