700-r4
Discussion in 'OffRoad Design' started by 1979jimmy350, Apr 17, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am swaping a 700-R4 for my thm350 in my 1979 Jimmy. I am going to use a short input shaft kit from advance adapters. I have stock suspension and axles. What else would I have to worry about to do this swap?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    First off, you mean a short output shaft I am sure. If you are using a NP205 the front driveshaft will hit the tranny pan. You should use the spacer instead and then there is no tranny tear down involved and no front driveshaft issues. /forums/images/graemlins/thumb.gif
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am going to use a NP 203 transfer case. I have to tear the tranny down any ways because it needs a rebuild
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The spacer is still cheaper than the shaft. The shaft is like $160.00 whereas the spacer is only $50.00. Don't forget you will also have to buy a kit for the lock-up convertor to work correctly.
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    with the np 203 is there still the problem of the front driveshaft hitting the pan and would I have to get a different rear driveshaft?
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I believe there are no driveshaft issues with using the 203. If you are replacing a TH350 the front driveshaft will be too short and the rear too long. The difference in length between a TH350 and a 700R4 is 1 7/8" the 700R4 being longer.
  7. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    No length issue, I am running a 700/203 with stock 350/203 shafts. Even when I had only 4" of lift and the axles in the stock location I had no issues. /forums/images/graemlins/thumb.gif
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The front output doesn't hit the pan on all TH700/205 applications, just the ones where you try to use the 3R CV instead of the 1310.
    With a 203, I think I'd be inclined to use the output shaft even more so that usual, since the thing ends up hanging off the back of the transmission adapter. Either way, the way the 203 is built, the only problems you will have are with the 'shaft lengths, not the clearances.
