700 to 400 swap..confused
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Jun 15, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Been searchin past posts for over an hour and am still confused on this swap... Have an 82 Blazer with a 700/208. I have a th400 sittin in the garage that came off a 205. Now I know I will need a new output shaft, and adapter for the th400 to bolt to the 208. Will the shaft out of the 700 fit in the 400?
    Still up in the air about the swap. Need you guyses opinions. On a budget so cheap is prefered (isn't it allways?). Heres my choices: rebuild 700 when it dies, plug 400 into the 208, find a 205 and adapter to go to my 400 and put em both in. Help!! What to do!!
    Have read on here that the swap is a pain and also that it isn't that bad... Well which is it? Thanx for the help!! /forums/images/icons/laugh.gif
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I had the same problem, minus an available th400. If you plan on using it as anything other than a slow driver, get the th400. Unless you can really afford a really good rebuilt 700R4.
    Anyway, I eventually got a used TH400 and NP205 combo and put them in. I kind of wish I would have went with a rebuilt TH400/NP208 but I'm very happy with my current set up. Indestructable in theory.
    For reference, the TH400 to NP208 adapter is about $400 odd bucks.
    I found the used Tranny Case combo for $600
  3. seslick77
    Jan 27, 2002
    220
    Now when you say adapter, do you just mean the piece that goes between the tranny and t-case? Or does that price include output shaft and tc input shaft? $400!! Ouch!! /forums/images/icons/shocked.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The shaft from the 700 won't fit in the 400. /forums/images/icons/frown.gif
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Is that price from Advance or Novak??
