700 torque convertor lock up
Discussion in 'The Garage' started by obijuan, Nov 21, 2006.
  1. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    how does the lock up activate? is it a wire or a vaccuum? the local tranny shop says i dont have lockup on my TC. do i need lockup with 35" and 3.08?
    thanks
  2. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    Hey i got a 700r4 in my blazer and lockup helps on the highway but with 3.08 gears you probably dont need it. there is a kit out there that is about $100 it comes with a silinoid that screws in the passenger side of the tranny and wires up for lockup it makes a big difference about like having a 5th gear. Anyway i think depending on the year....that there is a vacume activated silnoid somewhere around you brake booster that has a wire that runs down to the plug on the tranny. But the kit is the way to go.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The lock up is done electrically and it needs to be hooked up or you'll kill the tranny. Actually with 3.08's and 35" tires with the 700R4 it isn't going to last long anyways.
  4. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    whats a better gear ratio selection for highway to sort of extend its life?
  5. Moody
    Moody 1/2 ton status
    Aug 4, 2005
    232
    Yakima, WA
    At a minimum 4.10's....although with 35's 4.56's would be better.
