700 tranny question, please help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Feb 23, 2004.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    SInce yesterday my truck starts in second gear instead of first once in a while. I have tried to adjust the passing gear cable 1001 different ways but it seems to make no difference. It shifts fine from second to third and from third into OD. Also, if I shift it myself and take it through the gears from first to third it shifts fine. Any suggestions? /forums/images/graemlins/dunno.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there are two possibilities, one is the sprag is installed backwards, not unless it was just rebuilt and did it since installed.
    #2 is the governer. the valve is stuck, or the support pin is too long or missing.
    the governer is under a cover on the driver side near the rear. just pry the cover off and pull the governer out.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you dont have a passing gear cable. you have a throttle valve cable, and if it is not adjusted properly be prepared to replace your trans, because it WILL die. i'd say it sounds like you've got a sticking governor.
