700 (TV cable) to 400 (Kick Down)
Discussion in 'The Garage' started by ftn96, Aug 12, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Will I need to make or buy a different bracket to attach the kickdown to my TBI unit or can I use the existing TV cable bracket?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The Turbo 400 only needs to have a vacuum line run from the intake manifold to the modulator, and an electric kickdown switch wired in at the throttle pedal. The holes are already on the pedal bracket to mount the switch. /forums/images/icons/cool.gif One side of the switch goes to the kickdown connector on the tranny, the other side goes to a fused, switch 12V source. When you floor the pedal, the switch closes and tells the tranny to downshift. /forums/images/icons/shocked.gif
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    So, no additional purchases?
    Know anybody that wants to buy a TCI 700? /forums/images/icons/grin.gif
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nope, it's a pretty easy swap, except for mating your transfer case to it. What are you going to do there? Are you swapping in a different t-case or buying an adapter to make the current one bolt to the Turbo 400? Will you have to have the driveshaft lengths changed?
    Don't need a TCI 700R4 here. I've got a 700R4 with 7,800 miles on it, from the same 'vette that donated the TPI engine for my K5, laying in the garage. It's been in my way for 12 or 13 years now. /forums/images/icons/shocked.gif I'm sure that some day I'll find a use for it. /forums/images/icons/wink.gif
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    This 400/with adapter, is from a 208. I purchased a 241 32 spline input gear that I need to install. Then more than likely I'll have to have the Highangle 1350 Rear C/V shortened adn have the front lengthened. But I can split those up on different pay checks. /forums/images/icons/wink.gif Plus I'll prolly have to move the T-case shifter cover back 2" as well as elongate the whole. But the Dewalt 4 1/2" electric grinder is Ready. I believe that is the best tool I have ever picked up. /forums/images/icons/wink.gif/forums/images/icons/cool.gif
