700r-350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by balls of fire, Jun 14, 2003.
  1. balls of fire
    balls of fire Registered Member
    Dec 29, 2002
    66
    Round Rock, Texas
    Has anyone removed thier turbo 350 and installed a 700r. What is the spline count on the th350, and what about the output shat on the 700 is it longer then the 350. I know thay have the same bolt patten, just the 700's case is longer than the 350. /forums/images/graemlins/confused.gif
  2. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    They both have a 27 spline output, but the shaft sticks out farther on a TH700r4. I believe it is around 1.5" You can swap in a different output shaft to make it work. ORD sells one http://www.offroaddesign.com but the 700r4 has to come completely apart and it can get pretty spendy unless you can do it yourself. You can get an adapter from Exaxt axle. http://www.exaxt.ca/misc.asp It is basically a spacer that fits between your 700r4 and the stock T-case adapter to make up for the longer output shaft length. Mac at Exaxt is very helpful and should be able to answer any of your questions.
  3. 96chevy
    96chevy Registered Member
    Aug 19, 2002
    14
    Smyrna, TN
    Re: 700r-350 (need help bad!)
    Does anyone know where I can find an adapter to go from a NP205 to a 700R4? I've got a TH350 right now and it's givening me problems, and since I'll be driving to school everyday (30miles one way), overdrive would definetly help. I checked the link above and no luck, any ideas?
  4. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Advanced adapters
  5. blasterD
    May 24, 2003
    410
    Anchorage Alaska
    The 700r4-203 adapter from Exaxt will work if you have a 205 that originally came behind a TH350. The adapter bolts between the transmission and the t-case adapter. This mounting surface is the same for any transfer case that came from a TH350.
