700r-4 and 205?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, May 25, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Does the output shaft have ot been swaped in the transmission in order to bolt on a 205 T-case, A buddy of mine has told me it is a direct bolt on outside of driveshafts linkage and x-member. Anyone know what i have to do to make this work?
    Thanks,
    Mike
    You call that dirty!?
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Get in touch with Advanced Adapters, or check with Fitzall. They have the output shaft to fit a 205/203 t-case to the 700R4. The 700 will have to be taken apart literally all they way to change the shaft. Once the shaft is in, it bolts right up. The stock 4x4 output shaft for the 700r4 is way to long for the 205/203, they only require a shaft that extends past the end of the case by .875". The Advanced Adapters shaft is about $170, not sure of the Fitzall price.
  3. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    ORD has the shaft for you. $160 I think.
    "K5 Grand GT Blazer Silverado in the Netherlands."
  4. Ryan88Jimmy
    Ryan88Jimmy Registered Member
    64
    Winnipeg, Manitoba, Canada
    So can you bolt up the 205 to the tailhousing from the 700/208? (with AA output shaft)
    Ryan88Jimmy
  5. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Yes, but you need the adapter output shaft and the automatic style 205 case and trans adapter.
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  6. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I did this in my 88 blazer. I used a advance adapter output shaft and a 205 transfer case and adapter from a 350 auto equipped truck. You can also get a spacer for the end of the 700R4 and use the factory shaft, however this makes the overall length a little to long for blazers. The adapter is only 5/8 long and should be able to be found at any tranny shop.
    I may be slow, but I sure am fat!
