700R Cracked..
Discussion in 'The Garage' started by stockk5, Jun 14, 2006.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Well i am pretty sure i cracked my 700r.. i was an idiot and didnt connect my tranny braces to the motor mounts cuz the motor i dropped in didnt have the braces on them and everything was done b4 i noticed. But now i believe my tranny is cracked on the right side, directly behind or to the right of where the TV cable goes into it. I havent physically seen the crack yet, but whenever i park my truck on an angle to the right.. theres a huge puddle of tranny fluid on the ground, and it doesnt leak at all when leaning to the left. So if i do end up finding the actual crack is there anyway jb weld could fix it? or should i just drop the tranny and throw another one in. Any advice would be great. thanks
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I doubt you cracked it there, is this a new trans?? Did you remeber to put the O-ring under the TV cable?
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    its got about 60,000 on it... yeah i did put the o-ring for the dip stick hmm im trying to remember if there is a gasket for the tv cable where it bolts onto the tranny? ill double check that.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    There isnt a gasket for the TV cable its just a o-ring that slips over the little round piece that goes into the TV cable hole. I forgot to put mine in and everytime it leaned that way it poored out fluid.
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If you left em off, i dont think its a big deal because some people run plastic covers down there and some dont run covers at all. You cant use braces with either one, but I havent had any experince with it.
    Also: If your case was cracked you would lose most fluid and I dont think you could drive it.
  6. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    alright well thanks for giving me some hope. maybe in the chaos of just wanting to get it done i didnt put an o ring in..ill check soon.
