700R into 77 blazer...possible?
Discussion in 'The Garage' started by jpdanielski, Mar 3, 2006.
  1. jpdanielski
    jpdanielski Newbie
    Feb 27, 2006
    3
    Green Bay
    Ok my transmission is shot in my 77 blazer with a TH350 in to now. My question is, can i swap a 700R 4 speed from my 87 blazer into in with out modification?
  2. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    not w/o mods.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can, but you have to use the tcase and shifter and both driveshafts from the 87, you may need a conversion ujiont for the rear driveshaft at the differential, some are different, some arn't. you also need a TV cable bracket and spot on the carb to hook it to.
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    your so smart. what up TJ??!!! sorry for the high jack.:wink1:
  5. seschev3
    Jan 19, 2005
    308
    clayton, ca
    Don't forget the cross member and column indicator for OD.
  6. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can keep your old tcase using a spacer or special output shaft.
