700r output shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bushmaster, Mar 22, 2004.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    any 1 ever swap an output shaft on this tranny? is it a major job
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I have never done one myself, but IIRC you have to tear the tranny all the way down to change the shaft. If you are going to tear it down , you might want to look into a rebuild and some upgrades while you are there. Why are wanting to change? I assume for adapting over to the 203 range box for a doubler.
  3. bushmaster
    Jun 1, 2003
    146
    ct
    brand new raptor tranny now im thinking about using a 205 instead of the 208
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The shaft of the 700r4 comes out the rear but you have to dig most of the guts out to get it out anyway. There is a special tool required as well. The tool itself compresses springs for you so you can get all the parts out.
  5. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Not sure about swapping shafts but...
    Look into the adapter that lets you use the stock output shaft instead. It will save a lot of headaches with shaft to pan clearance and you don't have to swap out the shaft. I can't remeber the name of the adapter, something like Fitz-all, a search with"700" should get some results.
  6. bushmaster
    Jun 1, 2003
    146
    ct
    yeah thats what im looking for, /forums/images/graemlins/confused.gif hard to believe no one makes a coupler to go from 1 spline to the next
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    What is your 205 from, a 350? If it is from a 350 then it will bolt up with the 700 but use the spacer so you don't have your front driveshaft hitting the tranny pan. If you chose not to use the spacer then you need to completely tear down the 700 and replace the output shaft with the short version for use with the 205.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is no special tool required to get down to the output shaft snap ring. it took me about 30 to 45 min to swap mine out.
    pull the pan off
    pull filter out
    pull wiring
    pull valve body
    pull servo
    pull band retainer (magnet)
    pull governer
    pull pump
    pull band
    pull pull input assembly (reverse input drum and input housing assembly)
    inside the planetary gears is the snap ring for the output shaft. push the shaft up and remove the snap ring and pull shaft out
    installation is reverse of removal
    if you havent run it yet, you should not have to replace any gaskets/filter unless you damage them
    /forums/images/graemlins/waytogo.gif
  9. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  10. bushmaster
    Jun 1, 2003
    146
    ct
    dont know what to do . take a chance with 208 and hope it lives maybe put a sye in with a cv drive shaft. or spend 5-600 on adapters to run 205 and have some 1 open my new tranny /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
  11. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    run the 208, save your $$$ for other stuff
    the 208 even has a better low range /forums/images/graemlins/thumb.gif
  12. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I have a new in the box Tek Pak Fitz All adaptor/spacer that I need to sell. This adaptor/spacer will allow you to put a 203 or a 205 behind any 700R4 with no shaft mods. $70 shipped.
    Like Orion said, you'll get better driveshaft clearance using this spacer.
    PM me if you're interested.
  13. bushmaster
    Jun 1, 2003
    146
    ct
    what exactly is it ? a spacer and a coupler with 2 diffrent splines? i have a 205 that came from a 465 it has the corse 10 spline
  14. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    The spacer is just that,a spacer. It allows you to use a 700 with the stock output shaft(27 spline, IFRC) with a th350 version 205(also 27 spline) and the stock coupler and adapter. If the output shaft you originally posted about is the one from Advanced Adapters, it is just a shorter version of the 27 spline original shaft.
    As far as I know there is nothing readily available to hook the 10 spline 205 to a 27 spline 700. th350/205 was a common factory setup so people just use one of them rather go to the trouble of adapting the 1-other.
    If I were you I would just use a 208 or 241 unless you are dead set on a 205. If so, you could probably trade your 10 spline for a 27 spline version. Or better yet,just buy the 205 and adapter from Bigdaddyof2. /forums/images/graemlins/waytogo.gif
    This topic has been covered here a couple times, try a search. You might find the answers to most of your questions that way.
  15. bushmaster
    Jun 1, 2003
    146
    ct
    thanks for all the info guys im going to stick with the 208
