700r to a 203 or 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by vince13, Nov 12, 2002.
  1. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    Just wondering if anybody has done it or anybody knows where i can get an adapter for this. thanks
  2. Grim-Reaper
    7,385
    Atlanta
    I hear Steven Watson can get the shaft you need. www.offroaddesign.com
    I may be doing the same conversion and will post something when I do.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you can buy a shorter output and tear the tranny down, ORD sells it i think. good if doing a rebuild. or you can buy a spacer from AA. both cost about the same. if not tearing down the tranny i would get the spacer. its like an inch longer.
    since the TH350 has the same output in all 4x4 models and same spline count as the 700r just shorter then you can use any 205 or 203 off a TH350. then using the spacer or the new output it will bolt right up.
    the TH350 and the 700r4 are identical on the a$$ end with the exception or the output stick out length. like i said before about an inch longer on the 700r.
    Grant /forums/images/graemlins/thumb.gif
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    AA sells an output shaft like ORD!!!! Not a spacer!!!!
    You can get a spacer from a local transmission shop! I have the address if you're interested!!! Here are the pictures I took of it:
    It cost me $60 to my door!!!!!!! The output shafts cost $200-$400!!!!! Plus you have to tear down your transmission!!!
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    they sell both, but they both have thier ups an downs
    spacer ups, extra ~ inch of space. helps a TAD on drive shaft angle. cost less
    shaft ups, STRONGER
    shaft downs COST
    spacer downs, WEAKER.
    to me if you are going to rebuild the trans do the shaft, i feel it is worth it.
    but thats me.
    Grant
