700r to a Th350
Discussion in 'The Garage' started by JohnDeere, Feb 11, 2007.
  1. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    I know this has probly been stated before, but I'm not a paid member so I dont have the search function.
    well my 700r has craped out. Im thinking about swaping it out for a th350. What all is required to do this. and what is the lenght diff. so i might get away without having to buy a new drive shaft
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Check out Advance Adapters. You'll have to be careful, they may still have two different kits for the same conversion. I don't remember the details exactly, but if you're using a "car" TH350, you'll have to shorten the output shaft. AA will be glad to sell you a kit with a new short shaft, which requires disassembling the entire trans. The insider way is to cut the shaft. There's a jobber type manufacturer that sells kits to rebuilders, with instructions on cutting the shaft. I'm really stretching to remember but maybe "National"?
  3. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    dosent a 700r and th350 have the same output spline count. I know they both mate to a 208 transfer case.
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Uh, not nececessarily (sp?), I had to count mine. I got lucky, just had to cut-off the tail shaft.
