700r to np205???????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr.Chevy4x4, Nov 25, 2002.
  1. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Ok, what i have is a turbo 350 version 205 with the adapter. What will I have to do to mate it to a 700r? I'm sure this has been covered but the search didn't give it to me. Sorry for the noob question! /forums/images/graemlins/confused.gif
    Mike
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I just put a 205 behind my 700r and I think you'll need a 2in spacer. I think that would it....But knowing me I forgot something /forums/images/graemlins/grin.gif
    Eric
  3. CRAWLIN70
    CRAWLIN70 1/2 ton status
    Apr 26, 2002
    349
    ESCALON CA.
    you need to change the tailshaft the splines are diffrent. you can eathere get it form sierraoffroad.net or ord. i just got mine and it was like 200 bucks. both are sposer's of ck5
    /forums/images/graemlins/truck.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The splines are the same between TH350 and 700R4. As said before you can use a spacer or you can also install a output shaft from advanced adapters and then just bolt the TH350/205 adapter up just like normal.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Two ways to do this. The 700 and 350 use the same diameter and spline count output shaft. The difference is the 700 shaft sticks out farther from the case. You could shorten (i.e. cut) the 700 shaft down, but you lose spline engagement.
    Some people replace the output shaft in the 700 with one that gives the same stickout as a 350 and it will bolt directly to the 350 version of the 205.
    Others use a spacer that "takes up" the extra room.
    Some say the spacer adds extra stress (due to leverage), but having done the shorter output shaft route, I would have gone with the spacer because the way the 700 is designed, it causes problems with the CV joint and tranny pan. By using the spacer, you get enough clearance (and could possibly even run a 1 ton CV).
  6. CRAWLIN70
    Apr 26, 2002
    349
    ESCALON CA.
    But also keep in mind that the 700r with out the 2" spacer is already 2" longer then the t350. so if you run the 2" spacer and the 700r you are 4" longer then the t350. eathere have the rear shortened 4" and the front ext 4" or do the output shaft and move the eng. ahead 2" that is what i did. but then again it is just a personal preference
  7. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Where can you buy the spacer?
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Where can you buy the spacer that is needed to bolt the 205 behind a 700 with the stock output shaft?
  9. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    I had to lengthen the rear about 2in (I think it was) and shorten the front Shaft. The length of the 208 is longer than the 205.
    Eric
