700r4/203
Discussion in 'The Garage' started by metto, Jun 2, 2005.
  1. metto
    metto Registered Member
    Jan 17, 2005
    64
    Raleigh, NC
    can you mate a 700 to a 203? i have heard that 700's have a longer output shaft, never measured though. im asking because some one wants to buy my 203 and they want to mate it to a 700.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    It can be done one of two ways, swap output shafts in the tranny to one which is the same length as a TH350 that can be bought from AA or ORD, or use the 2" spacer and be done.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    4x4high is right on
    i went with the spacer i needed it fast and could not see rebuilding a good trany to put the new shorter shaft in
  4. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    also the case is close to the tranny pan and might cause problems. get the spacer.
  5. metto
    Jan 17, 2005
    64
    Raleigh, NC
    cant you just hack like an inch off the shaft and clean up the splines with a file? its not like the output shaft is hollow or anything
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you do that you won't have much spline engagement and thats not good.
  7. metto
    Jan 17, 2005
    64
    Raleigh, NC
    but if you use the 350 adapter it would place the 203 in the same position in relation to the 700 as it would have been on the 350, therefore it would have to be the same amount of spline engagement right?
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The TH350 has a shorter stick out on the output shaft than a 700R4 does. Also the TH350/203 adapter is only 1" thick whereas the 700R4/208 is 3" thick so if you cut 2" off the output shaft and use the TH350/203 adapter you will have VERY LITTLE spline left. Trust me, i was going to do this years ago and after doing some research found out it isn't wise to do it that way.
  9. Tux
    Tux Registered Member
    Jan 9, 2006
    14
    Phx
    Where can I get this spacer? another forum says there is someone here who sells them.
    Pj
  10. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I need to know this also!
  11. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Add me to the list? But What is price diffrence between Spacer and Output shaft?
  12. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    bought the spacer off another member and it works great!
  13. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    I spent weeks looking for the elusive spacer. Here it is:
    http://www.teckpak-fitzall.com/teckfitz/products/switch_kits.htm
    I believe the spacer is actually made for swapping a th350 in the place of a 700R4. I ended up not using the spacer. I'm going with the ORD shaft. I talked with the guys at ORD and they said the newer flange style front CV shafts can have clearance issues with the 700R4 pan. The older yoke style CV shafts are supposed to work fine. This is all for an NP205 to 700R4. I don't know if it's true for an Np203 or not.
  14. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Thanks for the link.
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    that is the exact spacer I am using to run a 205 behind my 700R4. It requires that the 700s output shaft be trimmed an 1/8"... but otherwise its a "bolt on" affair. Mine may be FS soon...
    j
