700r4- 205 combo ???
Discussion in 'The Garage' started by doctor4x4, Oct 29, 2003.
  1. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    well did this 1 withthe advance adapter output shaft intead of the spacer and now the darn front shaft hits the pan any ideas ??? Yes i allready angled the cross member every wich way
    does any 1 know if a shallow 700r4 pan is made ???
    if so who please
    thanks
    R
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Stock shaft?
    Is the hammer out of the question?
  3. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    yea had 2 shorten it a bit as there was never a 700r4-205 setup from the factory ( now i see why ) :-)
    as it hitting just on the edge of the big double joint
  4. jekbrown
    May 19, 2001
    45,032
    368
    Vancouver, WA, USA
    this is why everyone runs the spacer. /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif dunno what to tell ya dude... running a shallow pan isnt much of a solution... prolly end up toasting ur tranny over it.
    j
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I've saw one where they cut the pan and welded a piece of angle on that side to make a notch for the d-shaft. Sounds like a pain but might work.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This company makes several for the 700. www.yourcovers.com
    btw, where can I get one of those adaptors?
  7. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    My shaft didn't hit, but was awfully close. I clearanced my stock pan with a ball peen hammer.
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Randy, I have my 700/205 sitting in the garage and its apart...is there something I can check for you, It has the advanced adapter end on the 700 and no spacer ring...
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    Oh, and are you ready to do mine? Now that you have schooled your self on the install and some what an pro on the matter... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  10. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    How much clearance do you need? Can you notch the pan using a piece of exhaust tubing?
    Also how much lift on the truck? Just wontering cause I have the shaft and was gonna do this in the next year. Dont want these complications /forums/images/graemlins/thumb.gif
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I did the same thing years ago (now I would go with the spacer). I had a buddy cut a section of that corner out of my pan and weld in a piece. The thing that sucks is there is an accumulator over in that corner, so you can only cut so much. I had a couple spare 700's laying around so I used one and some silly puddy to mark where in the pan the accumulator was, and used that for making my cuts......hope this helps (also my d-shaft hit my pan and would have torn it open if I ever tried to spin it before I modded the pan).
  12. jekbrown
    May 19, 2001
    45,032
    368
    Vancouver, WA, USA
    spacer = goooood. not only is the tranny pan not a problem (even a deep pan like i have) but it makes the front shaft longer.. which helps the angles a bit. Im surprised AA sells any of those shafts.. their "solution" costs 3x as much, causes pan clearance issues, and is a pita to install.
    j
  13. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    WOW THANKS FOR ALL THE HELP GUYS /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    just like the computer world it will be a cut and paste as many of you have recomended
    and Tony P yea sure ill help ya with it give me a call & you got pm
    and thanks agin guys for all the sugestions from them here is what iam gonna do
    i am gonna take a spare stock pan and modify it and then run a small cooler with a thermo fan infront of it
    Man i love this site
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
