700r4-205 TCASE
Discussion in 'The Garage' started by RPM, Sep 24, 2006.
  1. RPM
    RPM Registered Member
    Jul 9, 2006
    7
    NM
    What’s the best way to adapt a 205 t-case to a 700r4? I have found out that Northwest Fab has a spacer so that I don’t have to change the output shaft of the transmission. Any one running this, and have some pictures? What is the clearance of the front drive shaft to the transmission pan? Thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    your best bet is the spacer, the short shaft reduces the drive shaft to pan clearence
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  5. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    I used the short shaft. The newer flange style front ouput will have pan clearance issues. The older yoke style front ouput will work fine. I plan to do a NP203 doubler in the future and didn't want the extra length of the spacer.
