700r4/208/and 33's, will it hold up
Discussion in 'The Garage' started by purple76pearl, Jan 19, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    700r4/208/and 33\'s, will it hold up
    on my 87 with a 700r4 tranny 208 t-case and stock gears, if i put a 4" lift on it, will they hold up with some 33's or should i change gears? even after gears is that tranny/t-case combo stout enough for 33's /forums/images/graemlins/k5.gif
  2. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Re: 700r4/208/and 33\'s, will it hold up
    What gears are you running? I've been running the same setup for about 30k miles with 3.08 running gear and no real problems. Doesn't have the pickup on the highway it use to, but I'll be fixing that when my 10 bolt finally poops out and I put my new running gear with 3.73's in. I run a large oil cooler on my 700r4, and keep a temp gauge on the trans. and it never has overheated. Thought I had some slipping from first to second, but it was just my tv cable that needed replacing. To make a long answer short, yes it will hold up.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Yes, yes and what gears are you running? I've been on that setup for 5 years, most of the time with 3.73 gears. No problems.
  4. Scott87K5
    Scott87K5 Registered Member
    Jan 19, 2003
    9
    Cuyahoga Falls, Ohio
    I have had that combo in for about 1 year. My truck has 120K, 10K of it with the 33's. It's been only been on the trail once though, but I did tow my boat a few times. No problem, though it was pushing hard to hold 65 mph. Mine's a 305 though...with 3.42's.
    Scott
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You should be fine with 33's. IF you go to 35's, YOu might want 3.73's.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It'll be a dawg on the hills big time with that setup. I'm running 3.73s on the 33's and I usually have to gear down to keep my speed up.
  7. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I've been running that combo for 3 years with no problems. I was told to stay out of over drive though. Prevents the tranny from searching for the right gear I guess. And bogging the engine.
  8. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    The 700 likes a large aftermarket cooler...cheap insurance, and well worth it....
