700R4 2wd to 4wd
Discussion in 'The Garage' started by petryshyn, Nov 30, 2004.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    I am getting a 700r4 out of a 2wd will this fit in a 86 blazer, or are their any differences betweeen it. It came out of a diesel does that matter. Also does a two year difference make anydifference, (two years older than the blazers.)
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I don't know all the exact spline count numbers and all that stuff, but I do know for fairly certain that a 2wd tailshaft won't bolt to a np208. You'll have to swap tailshafts, which entails a total teardown of the tranny. /forums/images/graemlins/crazy.gif Or I could be wrong.
  3. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    Anyone know if i would have to rip the tranny apart to swap tailshafts? From all i could find searching the net is that is the only difference, also that their is two different bolt patterns. What else should i know before i try this and find out it can't work. Need to know cause i found a cheap 2wd rebuilt 700r4. Thanks.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes you have to tear the tranny down to replace the output shaft. the only two bolt patterns is the 4 cyl/small v6 bellhousing and 4.3/v8 bellhousing
    if the tranny is a 84, i would look for another trans, the early ones are bad and had LOTS of problems, if your looking for a good used tranny, look for a 87 and newer. GM worked preaty much all the bugs out by then and are quite good trannys in stock form.
  5. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Diesel tranny's have a different tourque converter(stall speed is different)--it will bolt up to the gas motor,but it might feel like it wants to "creep"and lug the motor down at a stoplight.
    I thought they had a "spacer" thing you could use to adapt the 2wd to 4wd,by removing the tail on the 700R4? /forums/images/graemlins/confused.gif--I have seen a few in the junkyards,but I havent ever dealt with the 700R4 other than R&R them(LOTS of them!).Maybe an advance adapter part /forums/images/graemlins/confused.gif.
  6. muddinallday
    muddinallday Registered Member
    Aug 19, 2004
    48
    stationed in southern cali
    advance adapters has an adapter for the 2 to 4wd tranny swap. i put one into my k-5. you'll have to put a gas torque converter in it but thats it. or you can do the red neck way and just cut the tail shaft off til it fits. but yes it will bolt right up after you do that. my .02, add a good tranny cooler perferably one with a fan on the cooler. dont run the one into the radiator. ive burnt up 2 trannies then did the external cooler and havnt had a problem since.
