700r4 - 82' to 88' parts interchange
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ambritmann, Jul 14, 2002.
  1. ambritmann
    ambritmann Registered Member
    May 20, 2002
    23
    North Carolina, USA.
    700r4 - 82\' to 88\' parts interchange
    Can anyone tell me if the 4x4 output shaft and Diesel governer assembly from an early 82' 27 spline tranny will fit into a 88 onwards unit. I am going to rebuild a 88 onwards unit to eliminate a lot of the problems of the earlier transmission. It seems to be a lot easier to find a 2wd gas spec unit to use as a core so I need to change the parts over to suit my 4wd diesel Blazer.
  2. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    Re: 700r4 - 82\' to 88\' parts interchange
    You want the 89-92 version, it has the aux valve body (89 and newer), 29 tooth sprag (89 and newer), thicker roller bearing (87 and newer). I cut this section from another post I wrote the other day. As far as the output shaft it'll interchange, The AA shaft for the TH350 to 700r4 conversion is the same shaft for 82-92 and mabye even the 4L60E. I would also use the govenor out of the diesel, it will fit.
