700r4 adapter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hd44blazer, Nov 20, 2006.
  1. hd44blazer
    hd44blazer 1/2 ton status Premium Member
    Dec 21, 2005
    651
    172
    Antioch, CA
    Will the transmission to transfer case adapter that was between a 700r4 and np208 from an '86 p/u attach to a '93 4l60e with the same np208?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As far as I'm aware the cases were the same. The 700r4/4L60 was basically the same as the 4L60E but with out the electronics. A call to someone like Advanced Adapters should give you an idea.
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I think SouthernSpeed is correct. I also remember reading the 700 / 208 adapter is the same as the 350 / 203 but there are 2 versions of the 350 / 203 and it's the taller or hi version that is the same as the 700 / 208.
