700r4 and 203 is possible w/o AA
Discussion in 'The Garage' started by rhuarc31, Nov 26, 2005.
  1. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    K, here it is, it is possible to put a 700r4 to a 203 without a new shaft from advance adapters or a spacer. Cut the output shaft off between 1 9/16 and 1 5/8. Chamfer the edges. Easy so far right? Now take the tool of your choice, I used a dremel with a flexishaft and cut off wheel, and lengthen the splines to where the shaft widens out. It will now bolt right to your 203.
    Why do this? Well mostly cause I'm broke, no money to buy a new th350 since I cracked the case and fragged mine, but had a good 700 sitting around that'd I'd gotten as part of another truck and didn't use.
    In theory this could create durability issues, I know. But wheeled it pretty hard with no breakage yet. And if I do break it, well I'm not out any money, and hopefully I'll have a little more then so I can buy the output shaft from advance adapters and put it in.
    Also love the extra low first gear to help turn the 44's. Didn't even have to modify the drive shafts, since the front was a little too long already - what caused the tranny breakage - and the rear a little short. Though if you didn't have those problems to begin with ...
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    cool. dose this mean you can put a th350 in place of a 700r4?with out money.
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Think going the other way would be tougher -- making the shaft longer, as it were, is difficult.
    -- A
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    44s and a th700? Me thinks you want a th400. I wouldn't respline a tranny output shaft that way personally... Im sure if you were super careful it might work, but just using a spacer seems like it would work a lot better. If you can't afford the $50 spacer, you can't even afford the gas to go wheelin', so it shouldn't be that much of a problem...right?
    j
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    What if you use the longer TH700/208 adapter, and redrill the 203 for 6-bolt pattern? That should work too. ;)
  6. rhuarc31
    Oct 21, 2003
    94
    Decatur, IL
    Well the truck had a full tank of gas when I did this so didn't have to worry about that. And last I checked by the time I got the tail shaft from advance adapters and paid shipping, and paid someone to put it in I was getting a lot closer to $200. And you're right, I probably do need a 400 and 205, got one for free? Hell, I'm running a dana 44 front with those 44's, the front axles break long before the tranny :haha:
    Anyway the main point is that it is possible if you need/want a cheap fix and have the extra tranny lying around.
    Oh and on the 350 instead of a 700 try using a long tailshaft th350, maybe even one from a 2wd. That'd get you close enough to tweak it into place. And for the 208 adapter and redrilling the t-case, well I didn't want to have to take the t-case apart, and definitly didnt' want metal shavings in the case. Also I think it would interfere with mounting the shifter.
  7. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Hmmm. 700r4 with 203 and WMS 3.1 low range! :p: would that work? how about a th400 with 6 bolt adapter to 203 and 3.1? :D
  8. Tux
    Tux Registered Member
    Jan 9, 2006
    14
    Phx
    Does anyone know where to purchase above mentioned spacer kit?
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have a new one I didn't use. $65 to your door...
  10. Tux
    Jan 9, 2006
    14
    Phx
    hold that for me for a week and ill take it
    pm me for email details
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Shoot me an email at dpindustries@yahoo.com
    I tried to pm you, but got an error message saying you could not accept pms.
