700r4 and 205
Discussion in 'The Garage' started by muddawg, Jan 31, 2005.
  1. muddawg
    muddawg Registered Member
    Oct 24, 2004
    39
    Susanville, CA.
    What are my options for mating a np205 to 700r4? Do I need the AA short shaft or is there a spacer that can be used instead?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can get a spacer but i would get the shaft because you run less of a risk of breaking the spacer because the 205 is a pretty heavy case
  3. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    this was just talked about in other thread . and you want to watch the cv head on the drive shaft to tranny pan clearence. might be better off with spacer and a good brace to the frame on the side of the 205.
  4. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    Where can i get the spacer?
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    any tranny shop will have them . or post a thread in the wanted section on hear. you will need to put the spacer on and see if you have the correct length shaft to start. and if to long you will most likly cut some off and make sure you have full spline ingagement and dont bottom out on the end of the splines .
  6. sweetk30
    Nov 1, 2004
    25,547
    542
    go page 8 in here and look for the thread title (700r4/np205 front driveshaft clearence issues) its all in there about the problems.
