700r4 and 241 passenger drop
Discussion in 'The Garage' started by cybrfire, Nov 9, 2004.
  1. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Anybody know about what year that combination started and ended? Also who builds the best 700? Hear a lot of different builders but just curious what is considered to be the best one.
    The 241, Does it hang as low as the 208?
    Thanks.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Bowtie from every thing i have heard/read these are the best, if you pull a tranny t-case combo out of a truck the later the better,they seemed to have all the bug worked out by the later years, but 89 was the last year of a mech. spedo, they went to VSS after that
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I'm pretty sure most '89-'91 K5s and Subs (the 1/2 ton version) had this combo. As already stated, '89 had mechanical speedo and '90-'91 had VSS.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I've seen one 1988 Suburban and one 1988 K5 with a NP241. I think most got NP208s.
    The 88-89 ones had a mechanical speedometer and the 90-91s had a vehicle speed sensor.
    They hang down just as far as a NP208 and in my opinion are worse since the crossmember hangs down further than a "flat" style crossmember.
    If I ever find a 88-89 NP241 I'm going to use one of my "short" style adapter and a clocking ring so I can have the crossmember flush with the frame rails.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The 241 also has a better oiling system /forums/images/graemlins/thumb.gif
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    From what I know if 241's they are a better option. Especially since its easier to convert the output to fixed yoke.
    Thanks for the info.
