700r4 and edelbrock performer intake
Discussion in 'The Garage' started by wed68, Feb 15, 2005.
  1. wed68
    wed68 Registered Member
    Jul 27, 2004
    27
    OK the blazer is running well now but I am afraid to drive cause the tv cable which is mounted in the stock bracket on a new edelbrock intake seems to be way to tight.
    What do I do!!!
    Bill
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Theres an adjustment on the cable, right behind the clip there is a keeper style horseshoe clip. Pull it up and the cable will most likely slacken.....
  3. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    heres an article on tv adjustment. basically you depress the clip, push sheath towards firewall back into clip, release clip, manually give full throttle. it should click out a few clicks..
    http://www.tvmadeez.com/article/index.php
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    tight is better than loose, but adjust it anyway. the location can change a little bit with the aftermarket intake, and it will effect it.
