700R4 and NP205 answers !!!!!
Discussion in 'The Garage' started by TexasDan, Oct 14, 2005.
  1. TexasDan
    TexasDan Registered Member
    Dec 13, 2004
    28
    Texas
    I have for several months now been looking for a simple way of going from a Turbo 350 trans with NP205 TC to a 700R4 trans and the NP205 TC.
    Well the answer is simple. There is none. I purchased the 7Q35A that everyone seems to THINK :haha: will work. It want. Its to short. The Advanced Adapters has a conversion that requires a shaft change. Transmission Parts USA also has a adapter but requires the same change.
    The 7Q35A is only 1.875 inches long. A 700R4 trans less the tailshaft housing has 7.875 inches sticking out. The shaft is splined for 3.875 inches. The mounting bracket that connects the Turbo 350 to NP205 is 3.5 inches. The shaft out of the NP205 is 2.5 inches from the case, (1 inch inside the bracket).
    If you cut off 1.875 inches of the 700R4 trans. Create a 5 inch adapter of the 7Q35A then everything will work.
    I will be cutting the adapter at our shop next week and will post pictures when its done. www.ltw.net
    TexasDan
  2. joeysworld
    joeysworld Registered Member
    Oct 12, 2005
    7
    Bakersfield, CA
    Similar coincidence,
    I had just posted a reply on a th350-np203, to a 700r4-np203 conversion.
    I had a reply stating that there is an adapter for my conversion (mid seventies chevy updated from a th350, to a 700r4 trans).
    Have you thought about converting over to an np208?
    NP208 sounds like a natural conversion, but I may be opening up another can of worms since I am using a mid seventies chevy as my point of reference!?
  3. TexasDan
    Dec 13, 2004
    28
    Texas
    np205
    Not really. I have two NP205's. One was behind a Turbo 400 the other behind a Turbo 350. The 700R4 was a B&M version that came out of a race car.
  4. joeysworld
    Oct 12, 2005
    7
    Bakersfield, CA
    I'm really interested in the 700r4 coversion myself.
    Really for daily driving(gas expense), and for the lower first gear.
    Sounds like the 700r4 you got is a good one. I'd like to look into one like yours. From reading on your trans, it sounds like it's a keeper.
    Post back when you get a chance and let us know on how the projects going!
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like the tranny you have has the 2wd output shaft.
    the 4wd shaft does not stick out of the case anywhere near 7", its more like 4", maybe 3, havn't measured it.
  6. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,617
    604
    Hooper, Utah 84315
    The four wheel drive version is a lot shorter and you can cut it off only have to cut like 3/4 inch. Just buy the shaft from AA and get it put in or put it in had mine done for $60, worth every penny.
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Now I'm not the sharpest knife in the drawer but it sure as hell sounds like You have a 2 wheel drive tranny and not a 4 wheel drive one.
  8. TexasDan
    Dec 13, 2004
    28
    Texas
    700r4
    Yes it is out of a 2 wd. When someone ask if you want a 700R4 for free and all it needs is a torque convertor, you take it. The research that I've done shows that the 4x4 700R4 is much shorter. I had hoped that the splines on the tail shaft were a lot longer than they are.
    I now have a adapter to make a new adapter. It will have to be 5" long and I'll still have to cut 2" off the tail shaft. The company that I work for has it's own machine shop. I've allready talked to a few guys in the shop (hot rodders) that will help me at night to make the part. It will be made out of 4130 steel. I'll also make it so that it can be bolted to the trans first and then bolted to the transfer case.
    I'll post pictures on my web site when I'm done.
    Thanks to all the guys at this forum for some great help and ideas.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why does the trans need a torque converter? if its because the old one went bad, you might as well write off your free trans as a core, because its either toast, or will be very shortly after installation.
  10. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    the bolt threads on the tailshaft of the tranny wont hold, the adapter you are building is in going to allow to much twist . I did the 700-205 with a 4x4 tranny and a 3'' adapter and it would not hold, helicoild it and did it again ! with new motor mounts and t-case brace (frame mount) with new bushings (urethaine )
    I would just go with the short shaft :( ( lots of money)
    thats why I have a 350t in now
  11. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I guess god must have "miracled" my set up then... the $50 adapter + stock th350-to-np205 adapter works fine for me behind a 700R4. :surepal:
    j
  12. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    From personal experience I will would definitely say stay away from the AA short shaft. Use a stock 4x4 output shaft, buy the $50 spacer, and use a Th350/NP205 adapter.
    I used the AA shaft and flange style front output on my 205 and the driveshaft HIT the stock depth pan (NO way you could run a deep pan). I had to have a tinsman of mine modify my pan (i.e. cut it and patch it) to keep the driveshaft from hitting. Those that have the yoke style front output have a little more clearance and don't need to modify the pan, but I don't think they can get away with a deep pan either.
    Just my .02 after going through that. If I were to do it again, I would use the stock 4x4 output shaft and adapter without question.....
    You could probably cut a 2wd output shaft down to mimick the 4x4 shaft, but I would worry about spline engagement. I haven't researched it, so I don't know if it's a wise idea or not.
  13. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you have a 2wd 700 you need to replace the output shaft anyways and GM wants around 120 for the stock shaft while the AA short shaft is 150. I went throught the same thing starting with a 2wd tranny to mate it to a 203
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i want a 205 for my 700r4 so i can get fixed yoke, i was gonna convert my 208 but decided not to so i sold the parts.
    what is the exact spacer that will work with the 350-205 adapter to work perfectly?
    ive seen so many treads and they always sound so much more complex then just that???
    thanks
  15. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    There isn't one..yet. I am working with Jason to make one that will allow you to bolt everything up w/out having to cut or trim anything on either the spacer or the tranny. If folks are interested in it, I'll keep everyone posted as to what we make and how it works.
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yes keep me informed shane!! id love to send more money ur way :D
  17. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Me too!! Me too!!. I am wanting to do this swap soon, but am nervous about hacking the output shaft on a 700R4.
  18. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    I'd be interested in the spacer too. I talked with the guys at Offroad Designs and they said the older style 1310 CV joint doesn't hit the stock pan. It is only the new flange style 1310 CV joint that hits.
  19. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My experience exactly. In fact, it is one of the things that prompted me to do a doubler setup early. I needed clearance for my front driveshaft and even a 1310 CV with a smaller diameter shaft was going to be very close to the tranny pan. So, with the doubler setup and a modified crossmember, I am good to go. 700r4 w/ NP203 rangebox, ORD adapter, NP205 TC w/ triple stick setup.
  20. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    YES... Very interested! Pleae keep us informed!
