700r4 and np205????
Discussion in 'The Garage' started by rgood81, Jul 24, 2005.
  1. rgood81
    rgood81 Registered Member
    Aug 2, 2004
    17
    VA
    I ran my truck in a mud bog last weekend. everything went fine, but when I got home I had a big fluid leak, and a even bigger crack in my np208. So I called a friend of mine and bought his 27 spline np205. I've already figured out that I have to install the shorter th350 tailshaft in my tranny. I was wondering if anyone has done this before, and what kind of problems I might run in to. Someone told me that I might have problems with the front drive shaft hitting the bottom of the tranny pan. Is this true? Are there any other things to look out for? What are the possible fixes
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    there is a fix... use the $50 spacer instead of the short output shaft. Works like a charm and no trans pan issues at all even with my big HAD cv.
    unless you're a trans guru, I wouldn't recommend swapping output shafts... its the very last thing to come out of a tranny.
    j
  3. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    also it is not just a 350 shaft. its a custom unit. like above get spacer.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I'm considering the 700R4/205 combo now myself, especially since I've got a 205 in my garage collecting cobwebs...
    1. How long is this spacer?
    2. When comparing the overall length of a 700R4/slipyoke 208 to the 700R4/spacer/fixed yoke 205, which wins?
    3. Anyone make a combination spacer/clocking ring? Links?
  5. rgood81
    Aug 2, 2004
    17
    VA
    who all makes this spacer. are there any other issues I might have
  6. nmaggie99
    nmaggie99 Registered Member
    Jun 24, 2005
    11
    Anchorage, AK
  7. jarheadk5
    Mar 6, 2000
    4,389
    PA
    A little post resurrection...
    Still looking for answers to these exciting questions!
    I must be mentally defective or something - Google didn't tell me much and neither did searching here. I think it's a problem related to operator error... :doah:
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    2"
    If I had to guess, I'd say the 700/205 is shorter. Its been a looong time since I've had a 208 though. IMO you shouldn't even "go there" unless you are willing to lengthen/shorten your driveshafts or buy custom ones. I just bought some HADs.
    no... or if they do they are keeping it very hush hush secret.
    j
  9. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    My brother could prolly make the ring if you talk him into it :D
  10. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Thanks, J - I was beginning to wonder if anyone was listening...
    OK, so it's a 2" thick spacer. I'm not having much luck trying to visualize it, so I'm gonna have to find some pics online somewhere, or just wait until I get my truck apart to see how it all goes together.
    As far as driveshafts go - with a 52/56 spring swap and an axle swap planned, new driveshafts (probably HAD's) and a T-case e-brake were already in the plan. Thanks for the reminder though.
    IIRC, you're running a 700/205 combo - about how much does the case hang below the framerail?
