700R4 AND NP241 WILL IT HOLD
Discussion in 'The Garage' started by TOMER, Nov 2, 2002.
  1. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    Just bought Dana 60 front and 14 bolt rear with 4.10 ,will it work with the stock 700R4 NP241 and 33" mt/r ?
    If not please tall me what should I do?
    thank you all!!!
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Sounds plenty strong to me. It isn't much difference from stock.
  3. TOMER
    Sep 20, 2002
    38
    Israel
    I ask this question becouse some one how cald him self an expert told me that i need to swap the trany and the t-case to TH400 and NP205 becouse the axels are very big.
  4. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    They are big and add more weight but not enough to hurt anything. if/when you get large tires is when the transmission might have problems but there are plenty of people with your setup but larger tires and don't have any problems.
  5. TOMER
    Sep 20, 2002
    38
    Israel
    Yessssssssss!!!
    That's wandeful,I hoped to hear that ,now I can grind the calipers and bolt the axle on.
    And from what I anderstend (or want to understand /forums/images/graemlins/grin.gif) I can go with 35" ?
    Please corect me if I'm wrong.
    p.s. sorry about my english. /forums/images/graemlins/blush.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/blush.gif
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You will be fine with a 700r4/241. I was running that in mine with 1 ton axles with 4:56 gears and 35's. I am planning to leave the 700r4/241 in Donna's 90 K5 when I swap in the 1 tons with 4:56's and 36" swampers.
  7. TOMER
    Sep 20, 2002
    38
    Israel
    If I'll go with 3.73 , will it be less hard to the trany or not?
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    It will be harder for the trans and engine since you are running a lower gear ratio. Just make sure your tranny has a nice external oil cooler and you will be fine.
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would go with the 4:10's. I have 3:73's in Donna's 90 with 31" tires and that is just about a perfect all around combo in my oponion so the 4:10's should net the same results with 33's. One thing to help the trans last is to keep it out of overdrive unless you are cruising about 55 mph or above. Also if you do alot of in town driving the 4:10's will work better because your engine will not lug as much as it would with 3:73's and 33's. On my 89 it was stock with 3:42's and 31" tires and when I went to 4:56's and 35's I was actually getting better gas milage because of how much in town driving I do. The truck just didn't seem to work as hard going from light to light and being stuck in traffic.
