700r4 and oversized tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85GMCJimmy, Aug 11, 2001.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    I have just had my 2.5 inch lift installed, and will be going up to 33's this winter or so when my 31's wear out? Before i get my 33's should i do a gear swap first so i will not kill my tranny? The gears i have now are 3.07. So what do you guys think and give me some opinons, Thanks guys you are great!
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    With 33's I would say to go with at least 3:73's.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I was running that same set up for a long time. I toasted three 700r4s. Dont know if that is what caused all the problems or not though. I am now running a th400 and 3.73 gears.
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I just put 4.10's in with a 700r4 and I'm running 33x10.5x15 BFT A/T ko's.
    However, I blew my engine and tranny (non-related) if you'd like send me a PM and I'll let ya know how I like em if you'd like.
    <font color=blue> Jeff - may the force be with you</font color=blue>
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Its kinda pointless to spend all that money to only go to 3.73. Go to 4.10s you'll be much happier.</font color=blue>
  6. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    Your right, but when you blow your old 3.08s and the shop gives you 3.73s for the same price as 3.08s, its a pretty good deal. But I would also be happier with 4.10s, like biggray71 said.
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I'd say get what you want cuz the biggest expense in the labor, and you don't want to pay labor more then once.
  8. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    About 6 months ago I bought a 78 Jimmy iwth a 700r4 tranny and 33" BFGs. I just bought a set of 37s that I've been running for about a month now. I don't know what my gear ratio is, and haven't gotten around to taking the diff cover off and counting teeth, but is the 700r4 prone to overheating with big tires? Would an aftermarket cooler help, or do I need to get bigger gears. I'm assuming right now they're stock, but I don't know for sure.
  9. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    go 35's and 4.88's what the hell you got over drive you'll be at about 2100 at 60 and you love city driving
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I think you should change the gears first. Then go with the 4.10: 1 gear ratio. It is a good all around ratio for a 700r4 and 33s.
    Also. Get a good trans cooler
    <P ID="edit"><FONT class="small">Edited by Thunder on 08/13/01 06:22 PM.</FONT></P>
  11. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Heat kills trannies.... I would add the largest cooler I can find......
    C'moe
    <font color=black>the blazer is "Back in Black"
