700r4 casting #'s???????
Discussion in 'The Garage' started by outlaw612, Jun 15, 2003.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    700r4 casting #\'s???????
    Does anyone know where I can decifer the casting numbers or tell me wnere to get the info. I need to figure out what year the trans is. Here are the numbers:
    Casted into the case=8663548 and on a glued on tag=06TR and 864081.
    Thanks for your help.
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
  3. outlaw612
    Feb 11, 2001
    2,342
    Re: 700r4 casting #\'s???????
    Thanks for the link! According to that, the trans is an 88, I was hoping it would be the 82-86 style.
    Thanks Again!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Why? The '88 is a MUCH better tranny! /forums/images/graemlins/thumb.gif GM redesigned a lot of the internals of 700R4's for the '87 model year, due to an incredibly high failure rate of earlier models. They all have the some bolt patterns, etc. so the newer model will bolt into an earlier rig. /forums/images/graemlins/cool.gif
  5. outlaw612
    Feb 11, 2001
    2,342
    The only problem with the 88 and up trans is the auxilary valve body. In my 86, I had a valve installed that allows the lockup converter to automatically lock, this allows the electronics to be removed so I no longer have to worry about the converter not locking. With the newer trans you cannot use this valve. Its kinda like a failsafe, my wiring screwed up and burned up my last trans and now I dont have to worry about it. /forums/images/graemlins/thumb.gif
    Ive done alot of upgrades to the older trans also, its about as bulletproof as a 700r4 can be. (That is if you can say "bulletproof" and "700r4" in the same sentence) /forums/images/graemlins/rolleyes.gif
  6. tone91
    tone91 Registered Member
    Sep 13, 2000
    32
    Western Michigan
    Hey, is that the one that I traded you a few weeks ago?
  7. outlaw612
    Feb 11, 2001
    2,342
    No, this is a different one. I couldnt remember what year the one I got from you was and I was looking for a backup just incase it wasnt the right one. I just found out last night that it is the correct one though. /forums/images/graemlins/thumb.gif
  8. outlaw612
    Feb 11, 2001
    2,342
    When I talked to my trans guy last night he told me you can also look at the servo cover to ID the year. Right in the center of the cover will be a #, it kinda has like a star around it. That is the year. For example, a 3 is an 83, 4 is an 84....
  9. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    I heard if you install a check ball where the T/C lockup solenoid is you can eliminate all electronics and the 700 will lock up in 2nd,3rd+4th automatically.
    Got that info here
    More specifically here it's about half way down the page under "Idea using no lockup kit"
    /forums/images/graemlins/grin.gif
  10. tone91
    Sep 13, 2000
    32
    Western Michigan
    that's good. I thought the truck was pretty much all original when I bought it. Glad to hear it will work for ya. /forums/images/graemlins/thumb.gif
  11. outlaw612
    Feb 11, 2001
    2,342
    Im not sure how it was done, but all I know is I didnt hook up any wires and the lockup still worked. /forums/images/graemlins/thumb.gif
  12. outlaw612
    Feb 11, 2001
    2,342
    Yep, everything worked. Hopefully Ill have the truck back together by the end of July. BTW, did the parts cleaner work for ya?
  13. tone91
    Sep 13, 2000
    32
    Western Michigan
    Actually I haven't had to use it yet. I'm still working on replacing the floor in the rear of the blazer. But I'm sure it will work well. Thanks. /forums/images/graemlins/thumb.gif
