700R4 cooling line flare nut size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zcarczar, Apr 13, 2004.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Ive searched all over the place trying to find the freaking size of the 700R4 cooling line size. They are flare nuts like on a brake line and use a 1/2" wrench. Im trying to figure out my cooler situation and am going to use AN lines if at all possible from the the rad. to the cooler and back to the cooler line.
  2. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    I was thinking there are brass adapters (inverted flare) screwed into the trans case, screw them out & take them to parts store w/you.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're 5/16 flare.
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I believe a 5/16 to 3/8 line would be a -6AN fitting.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    5/16" is what GM has always used for gas engine auto trans cooling lines
    good luck
