700R4 cooling lines??????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skratch, Dec 27, 2003.
  1. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    OK, so I'm an idiot. /forums/images/graemlins/crazy.gif
    I pulled the lines off my tranny (700R4) and radiator without first figuring out which one went where!
    I'm about to go out and re plumb the system and need to know which line goes where. This is on an 87 Burb with 350tbi, 700R4, NP208.
    Does it go; top trans line to top cooler hole, and bottom to bottom or top tranny to bottom cooler?! auuuugh.
    Or should I be asking which port on the tranny is the output and which is the return line?
    Thanks,
    Mike /forums/images/graemlins/1zhelp.gif
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Top on a 700 is return. Connect the top radiator line to the top trans line.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    top to top bottom to bottom
  4. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Thanks guys, went and finished it up!
    Got the new cooler and filter installed as well.
    Thanks for the input /forums/images/graemlins/thumb.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i can look on my 700r4 in the caprice and see, but might be hard to trace along oil pan, humm
    hope how you got it now works for you
    good luck
  6. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    I'm gonna look under my Van before I fire it up and make sure it's the same way. I'm assuming a 4L60E will be the same as a 700R4.
    I ran the top to top and bottom to bottom and added the aux. cooler and filter in the top line so I'm hoping that is the return line as I was told.
    Either way it won't be hard to switch the lines at the tranny if I'm wrong. I just need to make sure it's right before I start it so no debris gets into the new tranny. /forums/images/graemlins/thumb.gif
